BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
ktula
Jun 05, 2018Apprentice
Do RBR50 and RBS50 use the same firmware? Both download links for RBR50 and RBS50 get the same RBS50-V2.1.4.16.img file on my MacBook.
- ktulaJun 05, 2018Apprentice
Oh i see the issue now. The firmware download site does not really allow you to concurrently download multiple firmware updates at the same time. If you do that, it will get only one version of the firmware update.
- FURRYe38Jun 16, 2018Guru - Experienced User
Ya, you should download one file at time to be sure.
- chirag884Jun 16, 2018Aspirant
That is so lame. Okay - so need to download only one file at a time.
Will be same version name, however should be two separate files, one will have RBR## and the other will be RBS##...
