BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Jun 05, 2018Guru - Experienced User
Should be different model #'s.
- ktulaJun 05, 2018Apprentice
This is what happened. I clicked on the link to the firmware update for RBR50 first, which opened a new tab in Safari. Then i clicked on the link for RBS50 and it opened another new tab. When i went to the tab for the RBR50 firmware update and click on "Download file", it proceeded to download RBS50-V2.1.4.16.img. I was incorrect when i mentioned concurrent download was an issue. Looks like the issue is with opening multiple tabs to different firmware updates in the browser (Safari). If you didn't click on the "Download file" link in the first tab to download the firmware update before you open a second or third tab for a different firmware update, the firmware update in the last opened tab will be the one you will be downloading even if you go back to the first tab to download that different firmware update.
- FURRYe38Jun 05, 2018Guru - Experienced User
Glad you figured it out. Ya, should be different model listed in the file name. Same FW version listed for all though.
