BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
mbski
Jun 05, 2018Guide
I am so sick of this pile of crap, wired backhaul causing the entire unit to crash every 5 seconds. WiFi is unusable with this new SW version. 2.1.4.16 Yes I’ve started with a factory reset, and have tried re-booting router and RBS50, no luck here. Had to ditch the wired backhaul. What a pile. Would never recommend this to my worst enemy. Netgear what gives? Are you employing incompetent people?
if one of my companies products worked like this we would throw our best staff at the problem, and work 24/7 to get it right. You are destroying your reputation by allowing this to continue.
frustrated consumer that gave netgear over $600.00 only to be regretting it.
