BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
DNichter
Jun 08, 2018Star
ARRIS SURFboard SB6190 32x8 DOCSIS 3.0 Cable Modem
DNichter
Jun 08, 2018Star
No other routers nearby.
- FURRYe38Jun 08, 2018Guru - Experienced User
Let us know if any of the suggestions help.
Also Try using manual channels on 1, 6 or 11 on 2.4ghz.
Your SB6190 does have a known issue, however I don't think that would be causing your problems here.
- DNichterJun 08, 2018Star
Yea I don't think it's the modem because all was working fine with my old router set up, and on the last firmware. Can I revert to the old firmware or will it auto update? Any suggestions on a router set up where I won't have constant issues?
Try the suggestions first before atteming to downgrade.
