BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Jun 08, 2018Guru - Experienced User
Let us know if any of the suggestions help.
Also Try using manual channels on 1, 6 or 11 on 2.4ghz.
Your SB6190 does have a known issue, however I don't think that would be causing your problems here.
DNichter wrote:
No other routers nearby.
DNichter
Jun 08, 2018Star
Yea I don't think it's the modem because all was working fine with my old router set up, and on the last firmware. Can I revert to the old firmware or will it auto update? Any suggestions on a router set up where I won't have constant issues?
- FURRYe38Jun 08, 2018Guru - Experienced User
Try the suggestions first before atteming to downgrade.
- DNichterJun 08, 2018Star
What suggestions? Nothing is clear on this topic. Try this, maybe that, is there an order to things, what should I try first, try all of them? I need clearer directions in order to do so.
