BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
ajnafets
Jun 11, 2018Guide
BretD wrote:
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other fixes. Please use the manual firmware upgrade process to apply to your Orbi.Release note:
- Fixes issues with the Apple HomeKit connectivity
- Fixes the wireless crash and reboot issue when the router is under stress
- Fixes WiFi disconnection and IOT issues
- Fixes an issue where devices on the Guest Network are able to see (but not connect to) some devices on the main network
- Fixes an issue where device boot order caused devices connected over Ethernet Backhaul to connect wireless backhaul
- Updates the OpenVPN certificate from MD5 to SHA-256
Hello Everyone,I have the Orbi RBK23 pack (1x router 2x satellite) the router is connected to an unmanaged switch (TP-Link) and both satellites are connectedto the router by wire which are connected to the switch.I have manually installed this firmware and my problems with disconnecting wifi signals are still their...But it seems to be better then before the update...I am also having problems that Facebook will not load pictures/ videos when turning the wifi of and connect to 4G it works fine.Turning wifi back on and it will not load again thats only through wifi with my cabled computer no issues...Can anyone think what could cause that?And I am not sure, but is the conclusion that the satellites are working better with or without the wired backhaul?Hopefully someone can give me some instruction because otherwise I will have to return this set and look for something else :-)Best regards,Stefan from the Netherlands
