BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
computersteve
Jun 13, 2018Apprentice
This constant factory reset requirement is unacceptable.... Orbi is aimed at consumers who want a wifi system you don't always have to think about & just works. I personally have the outdoor orbi satellite & it is mounted so the back panel isn't accessible making a factory reset extremely inconvenient on this type of setup. I am glad it is helping some users but I do hope that Netgear comes up with a much better solution. Factory reset should only be used as a last troubleshooting resort.
webminster
Jun 13, 2018Luminary
Obviously, /needing/ to do a factory reset, or worse, having a firmware update actually trigger a configuration reset, is antithetical to automatic updates.
- computersteveJun 13, 2018ApprenticeIt isn’t to obvious if that’s what’s being required every firmware update 😂
