BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
richromerman
Jun 16, 2018Guide
wow. so definitely do not upgrade to this firmware 2.1.4.16 if you want to be able to use the internet. Unbelievable.
and i thought 2.1.4.10 was bad.....
tagteam
Jun 16, 2018Virtuoso
I got 2.1.4.16 via autoupdate and it's worked well thus far (but then I had no issues with 2.1.4.10, nor any of the earlier releases).
- loomis1975Jun 16, 2018Luminary
I am able to access the internet on .16. Manually updated everything when they dropped the file for RBS50Y a while back.
Wireless backhaul with daisy chain in use, all the bells and whistles on, using ipv6 as well. No major issues and rarely any minor ones.
RBR50 and RBS50 are from launch (September 2016) RBS40 is from its launch and RBS50Y is from its launch.
I've tried the wall plug satellite RBW30 prelaunch, but it caused issues with the network so I kicked it to the curb.
I still wonder why there is such a giant disparity in user experiences with these units and the firmware.
- qskillzwfu25Jun 16, 2018TutorNo issues on my end either...I run in AP bc I'm on ATT fiber. I did as one member suggested and gave my Orbi router and Orbi satellite static IP addresses...along with a few other devices and everything has been Rock solid.
