BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
tdroz73
Jun 16, 2018Tutor
bwc_ wrote:
Feedback/status report for BretD
Having run 2.1.4.16 for a while now—a week maybe?—it has improved HomeKit. I cannot think of finding a device unresponsive since applying it. I have iDevice wall "switches", Lutron light switches, and a Hue lightstrip run from an AppleTV as the hub.
So far as iOS devices dropping off the WiFi, despite having a very strong signal, that's still happening, although, I'd say it's happening much less than before (but still more than a few months ago when this whole mess started.)
So odd - I have a number of Apple TVs, and 3 iPhone and 4 iPads on my network running os 11.4 and os12 beta and none of them have any issues with dropping the signal from the Orbi on this firmware. Are you updated on all your devices to latest iOS? Are you hitting interferance from a neighbor? I had to use WifiExplorer on my Macbook Pro in order to find clear channels on 2.4 and 5ghz - even in a single family home due to how over powered all Wifi APs are these days...
GadgetVirtuoso2
Jun 16, 2018Apprentice
Also been running the 2.1.4.16 firmware on my system. No issues with HomeKit or any Apple device having connectivity issues. Are all your units running the same version? If one of your satellites can't run this same version I would turn it off and see if the problem goes away. Homekit definitely did not work very well with 2.1.4.10. If the issue goes away you'll probably have to wait for this version for your particular hardware model.
If all of your units are running 2.1.4.16 then I would power cycle the router and satellites and see if that doesn't correct the issue. If it persists I would perform a factory reset with 2.1.4.16 installed on all units.
I'm running Wemo switches with the Homekit gateway, iDevices, and Ikea's connected lighting solution with several AppleTVs, Homepods,iPhones, iPads without any issue.
- cheshbrJun 16, 2018Apprentice
I’m running v2.1.4.16 with a wired backhaul I have a number of iDevicesall, some Wemo globes and a switch, an Echo Dot, a Google Home, a couple of TP-Link Kasa switches, and five Lifx globes, all of which connect and stay connected flawlessly. Until ‘16, I was having occasional issues with Lifx and HomeKit, but since upgrading to ‘16, none whatsoever.
Now Netgear, if it ain’t broke, don’t fix it.
