BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Stev3D
Jun 17, 2018Luminary
The Advanced -> Administration -> Firmware Update page told me that v2.1.4.16 was available, so I let it update my RBKR50 and RBKS50. Now several things are happening:
1) The satellite thinks it's connected as it should be, but the Web interface shows the satellite as just another connnected device, the number of connected satellites is listed as zero, and the attached devices list says that everything is attached via the router (when half of them should be connected via the satellite.
2) The Orbi iOS app indicates that my Orbi is not supported by the app -- except that sometimes it is, and sometimes it isn't.
Yes, I've tried power-cycling both, done the sync button dance, and tried the Web interface for adding a new satellite. In every case, I get the blue ring indicating a good connection. It's just that the logic in the router somehow refuses to recognize the satellite. This flaw is infuriating (it should just work).
Should I "downgrade" the firmware back to v2.1.4.10 ?
loomis1975
Firmware must be production because they are pushing it through auto update.
As for the most recent post, I recommend you just leave it alone for awhile powered on and give it time to sort itself, that is if all sats showed blue before turning lights off and router has no light. Sorry, but the time in my experience is indeterminate.
- e1supermanJun 17, 2018ApprenticeThat's silly. Do you work for Netgear?
The fix is to let our router sit idle for 24 hours every time we reset to let it work right?- loomis1975Jun 17, 2018Luminary
The fix is to let our router sit idle for 24 hours every time we reset to let it work right?No, I don't work for Netgear. This is a community forum, not tech support. You do know that Netgear has no responsibility to reply or even read these forums if they want to be difficult right?
Who said anything about letting a router sit idle for any period of time, or mention a certain time frame? Inordinate doesn't mean 24 hours.
Maybe I wasn't clear, but I didn't get any hints from the poster that actual network connectivity or internet access wasn't working for any clients, just that the diagnostics was all hosed. I meant to imply to ignore the diagnostics as long as the internet is working and check back in to see if the diagnostics are reporting correctly after an INORDINATE amount of time. I've seen the diagnostics synch up with reality in as little as 30 minutes, but as long as 3 hours.
I really feel for everyone having trouble with the crappy firmware implementations, especially those stuck outside of return windows and after the support window has closed.
I have no idea why the Orbi works very well for some and absolutely the worst network experience EVER for others. I use it as a Router on my own Netgear cable modem, wireless backhaul on, using daisy chain, with 2.4 ghz transmit power turned down to 75 percent, all the bells and whistles on, assign static LAN addresses outside of the DHCP range for the satellites.
- Stev3DJun 17, 2018Luminary
I've had to shut down my satellite becaue any device connecting to it has no connectivity to anything but other clients of the satellite -- in short, the backhaul is non-functional.
I think you may have tried this already, or you might think it isn't necessary, but you could move the satellite to the same room as the router, but NOT within 3 feet of it and power it back up and see if the backhaul is working. If it still is not working, I would try the next step, or just skip to the next suggestion if you feel that moving it isn't a suitable test. Another thing to try is to give the satellite a static IP address on the LAN. I like to give all my satellites a static IP address outside the DHCP range, but that might be overkill. I know this is a moot point if you can't seem to talk to the satellite through the router, but if you can access the satellite via its IP address or can see it listed on the connected devices page (whether it shows it as a satellite or just a connected device) its worth a shot. After giving it a static IP, I would reboot the router, and then reboot the problematic satellite(s). As you have already done way too many times before, wait for the satellite(s) to show a blue color and then test again.
If that doesn't work, I'd open a support ticket, or just return the things, if either of those options are still free/available to you. If they aren't I'd try the dreaded master reset on all units after the latest firmware is loaded (cause its just going to auto update back to it anyways if you revert), setup the master and satellite(s) in the same room, and try my suggestion about the static IPs again, power off, put them in their proper places and power back up.
- Stev3DJun 18, 2018Luminary
loomis1975, great suggestions [see #270 in this thread], but that wasn't enough. But it did get me thinking... The satellite had forgotten how to be a satellite, or the router forgot what its satellite looked like. So I did two things: I told the router to "Disconnect" the satellite it wasn't able to find, and I did a full reset (paperclip in recessed hole/button). After that, I introduced them ("Add a Satellite") as if for the first time -- and it worked. Many thanks.
