BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Deez72
Jun 19, 2018Tutor
Orbi sucks. They cannot get this right. I did not use it for 3 or 4 months because of poor performance. Set it back up, worked great, then the new firmware messed it all up again. I cannot even stream my Apple TV. Please fix this.
- madone28Jun 19, 2018Aspirant
Foolishly installed V2.1.4.16 today. At first everything seemed OK. Then started having intermittant problems with my gigabit FIOS connection. Kept loosing internet connection. Rebooted RBK50, rebooted RBS50. 5 seconds of internet connection. Did this over and over. Called Verizon spent an hour on the phone with tech support. Nothing. Finally in utter frustration went back to older version firmaware. Only one I could find in my DL folder was V2.1.3.4 Installed that. Internet back. Had been running V2.1.4.10 with no problems for a while. After getting running with V2.1.3.4 again I reinstalled V2.1.4.10. So far things seem to be working. Keeping fingers crossed.
- FURRYe38Jun 19, 2018Guru - Experienced User
Next time try a ERASE on the router after updating to v.16 then set up from scratch. Be sure not to enable the speedtest app, traffic meter and access controls as these will impact your 1Gb ISP service.
- steve8411Jun 19, 2018Apprentice
Please stop advocating a factory reset. You’ve done this for every release.
The code is flawed. You are only wasting people’s time.
i know you want to help, but you’re truly not doing any favors.
When the code is corrected, every one of us here will confirm.
