BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Stratguru
Jun 04, 2018Tutor
Hi BretD,
The Guest Network is still NOT isolated with this new Firmware version 2.1.4.16 in the link below. I can’t believe this is still an unresolved topic and we are continued to be taunted with this unless check box in the Guest Network Settings “Allow guests to see each other and access my local network” …. WHY do you hate us.. the loyal customer that goes out of our way to spend time writing on the community board time and time again about the same unresolved topic?... but I hear Orbi Pro is doing fantastic.. thanks to the Obri Home community complaining about this over and over again and johngm reading the post. Good job testing before you got my hopes up with the exquisite release notes..
- Fixes an issue where devices on the Guest Network are able to see (but not connect to) some devices on the main network
NOPE!
Coolie13
Jun 24, 2018Tutor
The router firmware in your download link is actually <RBR50-V2.1.4.10.img> please explain why?
And what about the auto firmware update in Orbi app? That firmware is <RBR50-V2.1.4.16.img>.
It is so confusing.
Please kindly clarify. THANKS.
- Coolie13Jun 24, 2018Tutor
Suspect that the main issue is with the Satellite. After a full day of monitoring on various combination of firmwares and set-up.
Satellite - 5G is more unstable. Dropping below -80dBm at regular intervals.
Tried the following. And in the order of most stable with wired backhaul.
<RBR50-V2.1.4.10.img> + <RBS50-V2.1.4.16.img>
<RBR50-V2.1.4.10.img> + <RBS50-V2.1.4.10.img>
<RBR50-V2.1.4.16.img> + <RBS50-V2.1.4.16.img>
Correction.............Was speaking too soon.
After 16hrs of trouble shooting. The conclusion is Orbi cannot support wired backhaul. (at least in my case.)
Final set-up = <RBR50-V2.1.4.16.img> + <RBS50-V2.1.4.16.img> on wireless backhaul.
The moment the Satelite is connected via Ethernet backhual, the entire Orbi is dead.
Only wireless is stable. Hence, for those whose home or office space is to far, get a 2nd Satelite. Or get another brand. NETGEAR failed us. Or cheated us.
