BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Jun 25, 2018Guru - Experienced User
Was both router and satellites updated?
Besure to power OFF the router and satellites for 1 minuted the power ON the router, then one satallite at a time. Should come back online.
Try using manual channel 1, 6 or 11 on 2Ghz.
Any other wifi neighbors near by?
GEMASON wrote:
After the update, I have been experiencing connectivity issues with one of the satellites that I have. The connection repeatedly is broken and reestablished. I was not having this problem until the upgrade was automatically installed on my network.
GEMASON
Jun 25, 2018Guide
We’re both the router and satellites updated? No. Several days ago, after I had recycled everything, they were all upgraded. The problem that I am having is with the communication between the RB50 and one of my satellites. It was solid before the update.
Is there a procedure for hardwiring the satellite to the RB50?
