BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Gorelash
Jun 26, 2018Aspirant
After the update, when i try running the internet speed test from the Netgear Orbi iOS app, the router crashes. Tried this several times, all with same result
Jun 26, 2018Guru - Experienced User
Does the router crash if you run the speed test from the routers web page?
Try a full reboot of the router and satellite, if same thing happens, try a full ERASE on the router and set up from scratch then test.
Whats the Mfr and model# of the ISP modem the Orbi is connected too?
- GorelashJun 26, 2018Aspirant
Either i'm completely blind, or just dumb, but i can't seem to find the speedtest option in the web ui.
NM! i found it under QoS.
Seems to work fine from the web ui.
Did a full reboot of the entire network before the last test from iOS app.
Just got ny network up running again, after erase, seems to be working now :)
Thanks for the tips
