BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Ulairi
Jun 27, 2018Luminary
oliveyang wrote:
Udpated to 2.1.4.16 fairly easily and no reported issues initially. Internet totally stopped working the next day so i don't know if they are connected. If I plugged right in to my modem internet worked so i knew it must be the orbi. Ended up having to to a factory reset plus setup of orbi via ethernet to get internet working again. It's been stable for the last day, so that's promising. However, I am seeing a significant drop in performance. If I run a speed test in a browser (via wifi) I'm getting 40 - 50 mbps, using the orbi app's speed test it is 150 mbps.
Hi, oliveyang did you fix your problem?
If not, try another factory reset. Yes it's a pain, but I have had good speeds since doing two resets a couple of months ago, per this thread: link.
oliveyang
Jun 27, 2018Tutor
No changes since I posted. Thanks for the advice. Ill try a second reset.
- computersteveJun 27, 2018Apprentice
So I think there is definetly something wrong with this firmware.. I have done the factory resets & had good results up until 2 days ago when I noticed the wifi speed seemed sluggish. So I checked at what speed was my iMac connecting to the orbi usually it has an MCS index of 9 and its in the range of 700 something mbs.. but when I checked this time it dropped to MCS index 7 and is consistently staying locked at 585 mbs. So I really do agree with the other users who say this firmware release cuts the throughput of the wifi. I haven't moved any of the devices, and they are located on oposite sides of my desk. Now when I reboot it jumps back up to MCS index 9 700 something mbs but then after like 5 minutes it drops back down to a locked 585 mbs. I also notice that unchecking / rechecking the options daisy chain, Fast Roaming, MU-MIMO, Implicit Beamforming do really nothing.. I notice no change. I will not reset this router again to defualts, I did so twice & I have an outside orbi mounted its a pain in the A$$ to unmount and resync. Netgear instructed us that 2.1.4.10 would be the firmware that required a factory reset it was never mentioned that 2.1.4.16 would also need that. A factory reset SHOULD NOT BE A FIX .... it should be used to get you back to a working state (out of the box state) but if the firmware is defective from the factory there is no point to keep reseting it.. it just resets the problem.
- pup0975Jul 19, 2018Star
I'm having the exact same issue with my Macbook Pro. I'm on 2.1.4.10. My MCS drops to 7 usually when I've moved my Macbook outside of the room the Orbi is in. Internet speed which is 100+Mbps usually caps at 40Mbps. Turning off the wifi on the Macbook and then turning it back on, usually bumps in the MCS back to 8 and my full speed returns. This issue has dated back to at least 2.1.4.10.
- FURRYe38Jul 20, 2018Guru - Experienced User
Try this:
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230
I'm having the exact same issue with my Macbook Pro. I'm on 2.1.4.10. My MCS drops to 7 usually when I've moved my Macbook outside of the room the Orbi is in. Internet speed which is 100+Mbps usually caps at 40Mbps. Turning off the wifi on the Macbook and then turning it back on, usually bumps in the MCS back to 8 and my full speed returns. This issue has dated back to at least 2.1.4.10.- computersteveJul 20, 2018Apprentice
Ok.. so what happened to any new beta updates... it seems as if progress stalled at V2.1.4.16 DarrenM
- oliveyangJul 01, 2018Tutor
i tried the second factory reset and it worked to increase my speeds back to what they were before. Getting 180mbps downloads. Thanks for the advice!
