BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Sukurin
Jun 29, 2018Aspirant
My Orbi is at V2.1.4.10. Everything is working well unless 1 iphone6 device. It wont connecting at main network, but when switch to guest network it work without problem. Should I update to this firmware? Its kind a bugging me to see that tiny problem, but I also afraid this firmware will ruin my network.
- FURRYe38Jun 29, 2018Guru - Experienced User
Go into the phones wifi settings and select the SSID that you are attempting to connect to...if you can get to the next screen, Select Forget This Network. Back out, I would reboot the iphone then try to access the SSID and pw again.
What iOS is the phone using?
- FURRYe38Jul 02, 2018Guru - Experienced User
Try the Forget this Network option under wireless SSID name on your phone. Then reboot the phone then try to connect it again to the Orbis main SSID name.
