BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Roamabout
Jul 01, 2018Luminary
Updated manually to 2.1.4.16 over two weeks ago. Most painless update so far. System has been rock solid since the update as it has been since I bought it in Feb this year. I liked the Orbi so much I bought the Arlo cameras which have also exceeded my expectations.
Router and two sats are in AP mode, wireless backhaul, large house with 30+ devices of all types. Verizon Fios router.
- JMU1998Jul 01, 2018Luminary
Using wired backhaul and AP mode. Can someone explain if I leave the sattalite as showing attached to main unit is OK or does it need to show as a sattalite? Seems to be working ok tired of using paperclip to reset it can I leave it like this until the next Firmware hopefully can fix this issue?
- FURRYe38Jul 02, 2018Guru - Experienced User
If it's working fine, then leave it. No need to change anything. It should show as WIRED if your using ethernet back haul.
