BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Roamabout
Jul 01, 2018Luminary
Updated manually to 2.1.4.16 over two weeks ago. Most painless update so far. System has been rock solid since the update as it has been since I bought it in Feb this year. I liked the Orbi so much I bought the Arlo cameras which have also exceeded my expectations.
Router and two sats are in AP mode, wireless backhaul, large house with 30+ devices of all types. Verizon Fios router.
JMU1998
Using wired backhaul and AP mode. Can someone explain if I leave the sattalite as showing attached to main unit is OK or does it need to show as a sattalite? Seems to be working ok tired of using paperclip to reset it can I leave it like this until the next Firmware hopefully can fix this issue?
- FURRYe38Jul 02, 2018Guru - Experienced User
If it's working fine, then leave it. No need to change anything. It should show as WIRED if your using ethernet back haul.
- JMU1998Jul 02, 2018Luminary
FURRYe38 thanks for letting me know it shows number of satellite attached as 0 but shows as attached device as wired, I will leave it like this tired of monkeying with it maybe next Firmware address this issue. using Orbi in AP mode currently with googlefiber 1GB up/down.
- FURRYe38Jul 03, 2018Guru - Experienced User
Should show 1 however something is hung up. IF it's working for you. Leave it for now.
