BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
JMU1998
Jul 01, 2018Luminary
Using wired backhaul and AP mode. Can someone explain if I leave the sattalite as showing attached to main unit is OK or does it need to show as a sattalite? Seems to be working ok tired of using paperclip to reset it can I leave it like this until the next Firmware hopefully can fix this issue?
Jul 02, 2018Guru - Experienced User
If it's working fine, then leave it. No need to change anything. It should show as WIRED if your using ethernet back haul.
- JMU1998Jul 02, 2018Luminary
FURRYe38 thanks for letting me know it shows number of satellite attached as 0 but shows as attached device as wired, I will leave it like this tired of monkeying with it maybe next Firmware address this issue. using Orbi in AP mode currently with googlefiber 1GB up/down.
- FURRYe38Jul 03, 2018Guru - Experienced User
Should show 1 however something is hung up. IF it's working for you. Leave it for now.
