BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Cicloforza
Jul 12, 2018Guide
Unfortunately updated to 2.1.4.16 using app without seeing note to update manually. Now getting frequent internet drops, so want to reinstall update manually, but when I try to download it to Explorer by using link given on the support site and try to extract it, I get an error msg saying Couldn't Mount File The Disk Image is Corrupted.
First question-How do I download the correct version of 2.1.4.16
2nd question-When I do download it, do I have to reset to factory defaults and then install, or can I just re-install the new firmware.
Thanks
cheshbr
Jul 12, 2018Apprentice
<p>att Cicloforza, re Post 517, try <a href="https://www.netgear.com/support/product/RBK30.aspx#download" target="_self">clicking here</a> for a link to the firmware you want. Or <a href="https://www.netgear.com/support/download/" target="_self">here</a>.</p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
