BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Cicloforza
Jul 12, 2018Guide
Unfortunately updated to 2.1.4.16 using app without seeing note to update manually. Now getting frequent internet drops, so want to reinstall update manually, but when I try to download it to Explorer by using link given on the support site and try to extract it, I get an error msg saying Couldn't Mount File The Disk Image is Corrupted.
First question-How do I download the correct version of 2.1.4.16
2nd question-When I do download it, do I have to reset to factory defaults and then install, or can I just re-install the new firmware.
Thanks
DarrenM
Jul 12, 2018Sr. NETGEAR Moderator
Hello Cicloforza
You can get the files from the support page I linked the RBR50 below you may need to search for your orbi model in the support page if this is not the model you have.
https://www.netgear.com/support/product/RBR50.aspx#download
DarrenM
