BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Cicloforza
Jul 12, 2018Guide
Unfortunately updated to 2.1.4.16 using app without seeing note to update manually. Now getting frequent internet drops, so want to reinstall update manually, but when I try to download it to Explorer by using link given on the support site and try to extract it, I get an error msg saying Couldn't Mount File The Disk Image is Corrupted.
First question-How do I download the correct version of 2.1.4.16
2nd question-When I do download it, do I have to reset to factory defaults and then install, or can I just re-install the new firmware.
Thanks
Jul 12, 2018Guru - Experienced User
You can get downloads here:
https://www.netgear.com/support/product/orbi.aspx#download
Yes, download the file, then use IE11 or FF browser with a wired connected PC and re-upload the Satellite(s) first, then the router. Factory ERASE or reset the satellite and router and set up from scratch...
Thanks
- CicloforzaJul 12, 2018Guide
Why is this so difficult? Ive tried many times to download the update on Chrome and Edge and I get the same message, the file is corrupt, when I try to unzip. Why does Netgear make everything so friggin' complicated? Anyone had success with downloading/unzipping this particular model update?
Thanks,
FURRYe38,
Please tell me what you mean by re-uploading the satellite and then the router.
Thanks,
- DavidShawPJul 12, 2018Star
It's unfortunate that so many people have repeated issues. I upgraded by clicking the "upgrade" link in the orbilogin.net admin page, and upgraded the base and both satellites with one click. I didn't use any apps, or download any firmware manually, and I've had no issues.
Circle still works great. I've had no reboots. Performance is fine (200+ Mbps wirelessly, 1Gbps wired) with 26+ devices connected. I can view video from my Ring cameras with no issues. None of my kids have complained, and they push it hard (usually 2-4 Netflix streams going in the house at any given time, plus both my teenagers playing multiplayer games).
When I first got the Orbi, I was disappointed in the reliability. However, the last 4-5 months it's really been flawless. The firmware upgrade that added Circle was the start of stability for me. I've been really happy.
BTW, neither of my satellites are hardwired. I do have some Sonos speakers plugged into the Ethernet ports on the satellites, but that's it.
- radamoJul 13, 2018Apprentice
My system seems much more stable and reliable now that I went back to a wireless satellite connection. I still see an occasional drop but I think the system doesn't handle roaming very well. When you move from the satellite back into range of the router. Seems to struggle a bit.
Glad your system is working well for you.
