BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Jul 12, 2018Guru - Experienced User
You can get downloads here:
https://www.netgear.com/support/product/orbi.aspx#download
Yes, download the file, then use IE11 or FF browser with a wired connected PC and re-upload the Satellite(s) first, then the router. Factory ERASE or reset the satellite and router and set up from scratch...
Cicloforza wrote:
Unfortunately updated to 2.1.4.16 using app without seeing note to update manually. Now getting frequent internet drops, so want to reinstall update manually, but when I try to download it to Explorer by using link given on the support site and try to extract it, I get an error msg saying Couldn't Mount File The Disk Image is Corrupted.
First question-How do I download the correct version of 2.1.4.16
2nd question-When I do download it, do I have to reset to factory defaults and then install, or can I just re-install the new firmware.
Thanks
Cicloforza
Jul 12, 2018Guide
Why is this so difficult? Ive tried many times to download the update on Chrome and Edge and I get the same message, the file is corrupt, when I try to unzip. Why does Netgear make everything so friggin' complicated? Anyone had success with downloading/unzipping this particular model update?
Thanks,
