BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
globespy
Jul 18, 2018Apprentice
Doesn't matter what I try (openDNS, Google, Cloudflare etc), is completely broken.
Thanks Netgear. You almost convinced me that you had your stuff together.
But nope. You don't.
kuan815
Jul 18, 2018Aspirant
globespy what is "completely broken" means? it's function problem? or else?
- FURRYe38Jul 19, 2018Guru - Experienced User
I believe the problem is a mis-configuration issue:
- CicloforzaJul 19, 2018Guide
When I updated to v2.1.4.16, the box for Disable IGMP Proxying was checked causing inablility to send/receive e-mails on Outlook 2010 and problems with internet connection. After troubleshooting other areas of my computer for several days, I finally found that to be the issue. Hope this helps others.
