BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Jul 19, 2018Guru - Experienced User
I believe the problem is a mis-configuration issue:
kuan815 wrote:
globespy what is "completely broken" means? it's function problem? or else?
Cicloforza
Jul 19, 2018Guide
When I updated to v2.1.4.16, the box for Disable IGMP Proxying was checked causing inablility to send/receive e-mails on Outlook 2010 and problems with internet connection. After troubleshooting other areas of my computer for several days, I finally found that to be the issue. Hope this helps others.
