BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
davida425
Jul 31, 2018Guide
Right now my router and satelite are running 2.1.4.10 and they are working great as is. It is saying that the update version is 2.1.4.16. Since my RBR50/RBS5 are working great with 2.1.4.10, I am hesitant to upgrade to 2.1.4.16 with all the problems I have previously read about in another thread. Any thoughts or advice? TIA!
valentinissimo
Jul 31, 2018Tutor
Good evening. If your system works fine then I would apply "Never change a winning team". So no. Don't update.
If you find in the release note anything which interests you, then you should update. The 16 release fixed for example the HomeKit connectivity. If you don't have HomeKit then you don't care. If you have HomeKit and it works then you don't care neither.
Bottom-line: Avoid this update if you can wait for a better release, and don't have regrets.
Regards
V.
Regards
V.
- FURRYe38Jul 31, 2018Guru - Experienced User
What FW are you currently using?
I presume your system is working ok?
Regards
V. - davida425Jul 31, 2018Guide
Thanks for your advice! I do not use Homekit, so no advantage to updating!
