BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
GEMASON
Aug 01, 2018Guide
Router mode
Modem: Touchstone TM822G Telephony modem
Aug 01, 2018Guru - Experienced User
Have you powered OFF The Orbi system, and while it's OFF, pull the batter from the ISP modem and unplug it from the power cable for 1 minuted then back on? Then power on the Orbi system?
GEMASON wrote:
Router mode
The ISP modem should be inpacting the satellite since its' on the LAN side of the Orib and not the WAN side...
- GEMASONAug 01, 2018Guide
I'm assuming that you meant "should not be". I agree, but I ony see this happen when the ISP's service has degraded.
