BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Zdman
Aug 02, 2018Guide
Came back here after a few weeks to see if there were any good updates. Sadly no fw updates so I still cannot use wired backhaul and QOS just seems to do nothing. I really hate to ditch an expensive router and 3 satellites and start over, but I am fast approaching that point. I am also updating my Amazon reviews and suggest anyone else who feels ditched by netgear do the same. By the way, I do realize that for many people this product works fine. It worked fine for me with on Router and one wireless satellite, but for complex setups, this expensive system just does not cut it.
JMU1998
Aug 02, 2018Luminary
Is there anyway to force the sattalite to utilize wired backhaul, it just keeps connecting as wirelessly. Main unit is in AP mode, tried factory resets on both and many reboots, swapped cables, synced via wireless to main unit and then plugged cable.
- ZdmanAug 02, 2018Guide
JUM - I have spent a lot of time trying to do just what you are asking and the answer is basically no. Why Netgear did not include this is beyond me. In my case, I could get the satellite up in wired mode by various power cycling sequences, but it would always go back to wireless (a very weak wireless at that). Also, when it went to wireless it seemed to cause data storms on my network - I beleive is i looping date from the wirelss to the wired side. For now, I repositiioned my satellites and am limping along with a week wireless daisy chain solution while I wait for Netgear to fix the issue.
