BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
craigbailey18
Aug 03, 2018Star
I notice a lot of complaints about the connectivity issues with the wireless between satellites and the router. I am not sure if this has already been discussed before, but since day one I have setup my orbi satellites with static IPs via the RBR50 and my system has been stable with that configuration. You guys can try that and see if it works any better for you.
JMU1998
Aug 03, 2018Luminary
All my devices, each one has a static IP entered into googlefiberbox and Orbi is in AP mode. I have brand new cat6 and cat7 cables. No matter what I try the sattalite does not show as connected sattalite. In an earlier post I detailed my setup and troubleshooting steps I have performed thus far. I have give up my useless attempts... too light for a boat anchor use, too toxic to set on fire, maybe might hollow it out use it as a vase for fake flowers.
- craigbailey18Aug 03, 2018StarOk got you. I have mine setup a little differently. I have my Verizon ONT box going directly into the RBK50 (Router Mode) and then the RBR50 daisy chain to the 2 RBS50s. Would you be able to configure your's like that or do you have to make the RBR50 run in AP mode?
- JMU1998Aug 03, 2018Luminary
For me atleast having Orbi in router mode was a complete and utter disaster and constant nightmare to fiddle with every other day. AP mode it is usable and I have given up and accepted my ignorance and mistake to purchase this based on reviews. I will live with it until I find a better alternative. just disappointed how Netgear Engineering dropped this like a hot potato after having us Beta test it for them for a year which is fine but when it was time for them to step up they went stone cold and abandoned us not even thanking us for Beta testing it for them with our time and our patience, not even a simple thank you...instead complete silence!
- FURRYe38Aug 03, 2018Guru - Experienced User
When you had the Orbi in router mode, did you bridge your ISP modem or use its DMZ for the Orbi in router mode? I would give this a try. Try just setting up the router and don't set up any satellites.
Also, it's possible that you may have bad HW and should look into getting it RMAd.
Not everyone is having these kinds of problems. Yes, we already know about bad ones in this thread. :smileywink:
