BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
cptspalding
Sep 01, 2018Aspirant
Please add USB network drive capability!!!! Its rediculous that your lower models have this feature and the Orbi does not. :smileysad:
- jblack68Sep 01, 2018ApprenticeI think there’s a bug in the firmware if you have sonos devices connected Ethernet to the satellite.
If you reboot the system, the satellite will not connect to the router properly unless you disconnect the sonos devices I.e. playbar and sub and the satellite will connect and then you can reconnect the sonos devices. Been annoying me for ages but as soon as I did that. Works perfect.
