BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Flash008
Jan 27, 2019Luminary
Furry,
Any comments about the newer firmware for Pro users? Anything Netgear would like to share with thier valued customers that come here to report thier problems, and seek fixes/resolutions?
Seems Netgear has new code in the oven, and it has reported better results.
So, it also seems these problems of performance we report wiht the GA version, don't seem to be limited or meaningless. As Netgear seems to be fixing the speed/throughput problem.
Would it be fair to say, "Manual firmware relaod, reset and placment" are not going to solve the problems for pre-Beta (GA) users?
Should we expect any features we requested MONTHS ago to be delivered?
@mrmattis wrote:
I have installed beta firmware, 2.2.2.20. Seems to be ok now. Last resultat was 478/437 using Samsung S9+ wifi. 2 meters from router. Using cable is full speed, 500/500.
I am refering to the thread...
https://community.netgear.com/t5/Orbi/Orbi-AC3000-Slow-wifi-and-is-getting-worse/m-p/1696628#M51096
Placesandspaces
Jan 27, 2019Apprentice
I will say that rolling back the firmware to 2.0.1.4 has worked out well so far even though my router has gone back to the latest firmware version, I after the manual rollback I did a complete factory reset of the router and satellites. One thing I did differently from my normal rebooting process is I used the smart wizard and totally let it set up everything except for changing admin page password, network SSID name and password. I used to get buffering often on my IPTV android boxes but it has been very smooth so far (probably just jinxed myself but whatever). I wonder how many users who are having good experiences with the Orbi used the smart wizard vs those who didn’t like myself and what their results have been?
- Flash008Jan 27, 2019Luminary
Very glad to hear it Placeesandspaces,
Further confirmation there is a problem wiht the newer FW....
It also seems there is a newer FW beta code floating around in secret that solves speed problems for Orbi. It’s a shame Netgear will not share it, and insist the problems reported are the users fault…
- PlacesandspacesJan 27, 2019ApprenticeI agree and Netgear should definitely allow the consumer of the Orbi product to determine what firmware they want to keep versus forcing an auto update. Should be one button to click in the firmware update section of the GUI that you can opt out of new updates. That is inexcusable not to allow that. I have seen some posts where people use Telnet or something to block the Orbi updates but I have no idea what Telnet is and I would probably screw things up worse trying to use it.
- FURRYe38Jan 28, 2019Guru - Experienced User
Looks like this will make some people happy:
