BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Flash008
Jan 27, 2019Luminary
Very glad to hear it Placeesandspaces,
Further confirmation there is a problem wiht the newer FW....
It also seems there is a newer FW beta code floating around in secret that solves speed problems for Orbi. It’s a shame Netgear will not share it, and insist the problems reported are the users fault…
Placesandspaces
Jan 27, 2019Apprentice
I agree and Netgear should definitely allow the consumer of the Orbi product to determine what firmware they want to keep versus forcing an auto update. Should be one button to click in the firmware update section of the GUI that you can opt out of new updates. That is inexcusable not to allow that. I have seen some posts where people use Telnet or something to block the Orbi updates but I have no idea what Telnet is and I would probably screw things up worse trying to use it.
- FURRYe38Jan 28, 2019Guru - Experienced User
Looks like this will make some people happy:
