Mrpopup's avatar
Mrpopup
Tutor
Mar 27, 2019
Orbi Firmware V2.3.0.32
Netgear site still shows that Orbi Firmware V2.3.0.32 is NOT to be installed in Australia (so I assume also NOT in New Zealand).
Is this still correct, or can NZ'ers and Aust'ers install this update on RBR50's and RBS50's?
Thank you.
  • Thanks for letting us know. Please mark your post thread as solved.
    Enjoy.
  • FURRYe38's avatar
    Note:
    If you’re manually updating the firmware using a browser, you cannot update the firmware directly to v2.3.0.32. You must first update the firmware to v2.2.1.212.  After updating the firmware v2.2.1.212, your Orbi router will reboot, and then you can update to v2.3.0.32.
    If you are located in the following regions Japan (JP), Australia (AU) and Canada (CA) please hold off updating to FW 2.3.0.32
    Though NZ is not mentioned. since your in the same region as AU, I presume this includes NZ.
    https://kb.netgear.com/000060603/RBR50-RBS50-Firmware-Version-2-3-0-32
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Mrpopup
    Welcome to NETGEAR Community!
    Were you able to update the firmware?
    Blanca
    Community Team
    • Mrpopup's avatar
      Mrpopup
      Tutor
      Hi,
      No have not updated as yet as the ‘hold off’ message is still showing on the Netgear website for AU area users.
      Thanks.
      Cheers.
      • Blanca_O's avatar
        Blanca_O
        Hi Mrpopup
        A new firmware (v2.3.1.44) was posted and it fixes the firmware update issue for Japan, Australia and Canada. Please click link to download the said firmware.
        Blanca
        Community Team
