dmdz
Jul 18, 2020Aspirant
Orbi flashing white/Unable to join network/
After a power outage, my Orbi RBR50 with 2 satellites are not working . Tried to setup new system via the app on my phone and at the end of installation on my phone it says unable to join network ORBI...
dmdz
Jul 19, 2020Aspirant
The reset button doesn’t turn amber when holding for 15 seconds. Tried 40s but turns red, blinks, then turns solid green. Still doesn’t work. Untied TFTP using terminal on Mac but reset button needs to turn amber per instructions but it doesn’t. What do I do? Orbi triband wifi system/Comcast internet/modem surfboard sb190
Jul 19, 2020Guru - Experienced User
Try using a windows 7 PC?
I had problems using a Windows 10 PC then switched to Windows 7 and it worked. You maybe seeing same issue on Mac.
What OSX version are you using?
If nothing works, then the RBR maybe bad. :smileyfrustrated:
