ymc226
Dec 08, 2016Aspirant
Orbi for family and Apple Airport Extreme for guest?
I'm going to install my Orbit with 2 satellites tonight. I have Verizon Fios for internet/TV/phone and am using their Actiontec cable modem/router with the wireless turned off with an Apple Airport ...
- Dec 08, 2016
ymc226 wrote:Thanks for your response.
Is there a way to specify the channels on the Apple and Orbit routers? I'm not tech saavy but remember some screen on the Airport preferences in Mac OSX that did state something about channels. (Still at work so haven't opened the Orbi yet).
When you state how much separation, do you mean physical distance between the routers? My understanding is that there is no provision on the Orbi to create a separate "guest" network, thus my inquiry.
hi
yes both the extreme and orbi can be set to separate channels , its usually found in the wifi section of each device
with the latest firmware orbi now has a guest wifi setup
with regard to separation im was referring to do you want the guest wifi to not see your home network eg isolated as that would be tricky the way you wanted to do it , but the guest wifi in the orbi will allow you to isolate the guest devices
ymc226
peteytesting
Dec 08, 2016Hero
hi
- ymc226Dec 08, 2016Aspirant
Thanks, I didn't realize that Orbi now has Guest capability. I'll take down my Airport Extreme once I can confirm the Orbi works throughout the house.
