LarryC1957
Dec 23, 2016Aspirant
Orbi Guest Network Access Control
If the access control option to Block all new devices is selected, do this also block all new devices from accessing the Guest network ? If so, how does one block just new devices on the non-guest N...
DarrenM
Dec 29, 2016Sr. NETGEAR Moderator
Hello LarryC1957
It shouldn't block devices on the guest network if it is isolated from the main network.
DarrenM
- tsutazJan 03, 2017GuideMy wife attached to our guest network and when I looked at attached devices, the iPad was blocked. She wasn't able to do anything. I just purchased my Orbi and installed on Dec 28th, 2016. So, is there a way to separate blocked devices on Guest network vs Home network? Thanks
- DarrenMJan 05, 2017Sr. NETGEAR Moderator
Hello tsutaz
Have you updated to the latest firmware 1.4.0.34 customers have reported that is has been fixing the issue where devices show as blocked.
DarrenM
- tsutazJan 05, 2017GuideHa!, at the time of my posting on Jan 3rd, if memory recalls correctly, .34 firmware was not avail. My ORBI is on an AUTO update mode, so I will check this afternoon when I get home. Will post my findings back here. Thanks
- LarryC1957Jan 05, 2017Aspirant
Is the Orbi guest Network isolated from the Non Guest Network by design ? If not, I guess the answers is when Block All Devices is on then all devices are blocked regardless of which network they're on.
- rhester72Jan 05, 2017Virtuoso
LarryC1957 wrote:Is the Orbi guest Network isolated from the Non Guest Network by design ? If not, I guess the answers is when Block All Devices is on then all devices are blocked regardless of which network they're on.
It is.
Rodney
