LarryC1957
Dec 23, 2016Aspirant
Orbi Guest Network Access Control
If the access control option to Block all new devices is selected, do this also block all new devices from accessing the Guest network ? If so, how does one block just new devices on the non-guest N...
DarrenM
Dec 29, 2016Sr. NETGEAR Moderator
Hello LarryC1957
It shouldn't block devices on the guest network if it is isolated from the main network.
DarrenM
LarryC1957
Jan 05, 2017Aspirant
Is the Orbi guest Network isolated from the Non Guest Network by design ? If not, I guess the answers is when Block All Devices is on then all devices are blocked regardless of which network they're on.
- rhester72Jan 05, 2017Virtuoso
LarryC1957 wrote:Is the Orbi guest Network isolated from the Non Guest Network by design ? If not, I guess the answers is when Block All Devices is on then all devices are blocked regardless of which network they're on.
It is.
Rodney
