mach743's avatar
mach743
Follower
Nov 24, 2017
Orbi guest network setup
I've been running an unsecured guest network along with my secured network. Recently, I changed the open guest network to a password protected network becuase a neighbor was logging onto my guest network.  After doing so, two guest networks appeared on my system, one was secured, and one was open.
I turned off the password protection and my system reverted back to one open guest network.
Is there a way to have a secured primary network and a secured guest network, and no open guest network?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you tried to disable the guest network then try to re enable it and apply the password?
    DarrenM
