DanTheMan0
Oct 08, 2021Tutor
Orbi Guest WiFi network disconnects from internet periodically
I've seen the multiple posts and all the posts say "solved" but they are clearly not solved. Just as title says, Guest WiFi internet connection is dropping out periodically. Signal for Guest WiFi is ...
DanTheMan0
Oct 09, 2021Tutor
Thanks, i'll post it there. Seems like a huge oversight if this many customers are having trouble.
Oct 10, 2021Guru - Experienced User
Thanks for posting there.
Good Luck.
