KKE55
Apr 30, 2018Guide
ORBI, How many satellites does my router support?
I have a Router (RBR50) and two satellites (RBS50). I'm planning to add another satellite. Will the Router support it?
- Retired_MemberMay 01, 2018
yes
keithcghooks
May 19, 2018Aspirant
Can i connect three or more indoor satellites and two or mor outdoor satellites?
May 19, 2018Guru - Experienced User
I think i've seen someone post that they connected 4 satellites. Not sure if using 3 indoor and 2 out door. Might be a stretch.
- tydmeterMay 22, 2018Guide
I have four satellites plus the router and they all work fine.
Bill_S
- FURRYe38May 22, 2018Guru - Experienced User
Just curious, how do you have yours set up? Any Daisy Chain configurations? Or just Star?
Bill_S
I just have them in a star config. Originally I was unaware of the 3 satellite max. I purchased a fourth satellite and simply plugged it in. It immediately configured itself and has been working well for a couple of weeks. Whether there will be future problems I don't know but for now it seems to be working well.
Bill_S
