ronnie9ball
Apr 25, 2017Aspirant
ORBI, How many satellites?
Scenario: I have a classroom that has up to 20 computers for students to use. The building is old and company policy dictates there will be no modifications made, including adding network cabling. ...
- Apr 25, 2017
Orbi is not the right solution. A single classroom is a small area. Twenty computers is not many. Buy 3 to 5 APs, like the ubiquity AC-PRO or AC-HD, put each on a different 5GHz channel, and connect a few PCs to each AP. You will have many times the throughput. With Orbi all PCs would share the single 5GHz backhaul.
rhester72
Apr 25, 2017Virtuoso
Oof. Cut the number of satellites and add unmanaged switches hanging off them instead.
Rodney
ronnie9ball
rhester72,
Keep in mind, I have walkways that cannot have cable lying in them. Adding unmanaged switches doesn't fulfill the requirment of eliminating cabling. So back to the original quesiton: How many satellites can be connected to an ORBI router?
Thanks,
Ron
