ronnie9ball's avatar
ronnie9ball
ORBI, How many satellites?
Scenario: I have a classroom that has up to 20 computers for students to use.  The building is old and company policy dictates there will be no modifications made, including adding network cabling. ...
  • st_shaw's avatar
    Apr 25, 2017
    Orbi is not the right solution. A single classroom is a small area. Twenty computers is not many. Buy 3 to 5 APs, like the ubiquity AC-PRO or AC-HD, put each on a different 5GHz channel, and connect a few PCs to each AP. You will have many times the throughput. With Orbi all PCs would share the single 5GHz backhaul.
