polopolo
Feb 09, 2017Follower
Orbi IGMP BT Youview multicast IPTV
Hi, Bought this 400£ system supposed to stream 4K and I am still under shock that it doesn't support BT IGMP. Is there a workaroung ? Is this coming soon ???
Retired_Member
Jul 06, 2017That was exactly my issue and it turned out to be a bug with the firmware. They fixed it in a beta version then broke it again with the subsequent public release.
What firmware are you running? Beta 1.12.0.12 has it working again.
martyfp
Jul 06, 2017Luminary
OK - so I am not going mad then. :smileyfrustrated: It's been driving me nuts trying different things to kick it into life.
I am running 1.11.0.20 but have just requested latest 1.12beta... finger's crossed.
Many thanks - I will update....
- Retired_MemberJul 06, 2017
You may already know this but a quick test of BT TV multicast is to open rtp://234.81.130.4:5802 in VLC on any PC or Mac on your network. That's the BT test channel.
It sounds like you've already done it but just incase this is what I had to do on my Vigor 130: https://www.draytek.co.uk/support/guides/kb-vigor-130-bridge
