cdricc
Dec 05, 2017Tutor
Orbi in AP mode and IP TV connected with ethernet cable to satellite
Hi everybody, I'm new to Orbi, I installed a RBK50 in AP mode. The main RBR is connected to the ISP box. The satellite RBS is at another location. Several devices are attached with a cable to the...
SBM7815
Dec 05, 2017Initiate
I have a similar setup and the issue was the Satellite constantly disconnecting. This problem only started with patch 2.0.0.74 for myself and many other people. Luckily, they just released 2.1.1.12 and you can upgrade manually if you want or wait until they make it automatic. You'll be able to see the status of your backhaul connection and determine if you need to place your satellite in a different spot. Things seem like they are back to normal for me, but I guess I'll be watching it over the next few days.
cdricc
Dec 05, 2017Tutor
Thanks for this quick answer.
I noticed it freezes randomly after a few seconds, sometimes 1-2 seconds, sometimes 30 seconds... Then I change to another channel so that it unblocks, and a few seconds later... next freeze.
I'll wait for the automatic update and cross fingers hoping it effectively solves this issue.
