dopey1620
Jan 26, 2019Star
Orbi in AP mode with wired backhaul showing weird behavior
I recently set up an Orbi RBK53 system in AP mode (I don't need the orbi's router capabilities, as I'm using pfsense). The main orbi router is connected into a gigabit switch and one of the satellit...
dopey1620
Feb 17, 2019Star
I wasn't aware of problems with green and managed switches but now that I do some more digging with specific search terms yeah it seems like lots of people have been having the same problem.
I just switched to a zyxel gs1900-24 managed switch and am tinkering with the igmp snoopings settings but it hasn't made any difference.
Still good to know. Having the satellite wired directly into the router ethernet port is doable for now. I've followed up on my support case to see if they can tell us what protocol(s?) are used for the router/switch discovery and syncing.
- dopey1620Feb 17, 2019Star
Oh and one other good news. Now that the satellite is actually connected to the router directly and everything apperas to be working fine, daisychaining is doing what I want. Satellite-2 is connected to the wired satellite-1 instead of directly to the router. Signal strength to satellite-1 is much better and everything works great.
- ekhalilFeb 17, 2019Master
Great that things look good now.
One thing to be aware of is that wired backhaul together with Daisy Chain is not a good combination in the current software because of a software bug! Avoid having wired devices to the satellites for now until this is solved.
There is a beta software that is now being tested and it seems that this issue is addressed there :)
I've seen alot of comments to that but I've had a hard time finding specific details of the problem. Do you have a link to a post or something that describes what the problems are? So far so good for me :fingerscrossed: but it'd be good to know what problems I might run into.
- FURRYe38Feb 19, 2019Guru - Experienced User
Yes, others have reported that disabling IGMP protocols on managed switches resolved problems with connected Orbi and Satellites. If this works then your managed switch will be fine to use. Just keep this in mind.
- dopey1620Mar 12, 2019Star
To close the loop on this, interestingly enough 2.3.0.32 resolves the issue with the app showing the right status for the satellite when it and the hub are wired into a common switch (i'm still using the zyxel gs1900-24 managed switch and igmp snooping is currently set to disabled - default config for the zyxel).
If I'm connected to the wired satellite, it still doesn't resolve www.orbilogin.com properly. I still haven't had a time to hook up a hub to analyze the traffic to determine how that is detected though. But it's nice that basic functionality seems to be mostly working properly with 2.3.0.32 though.
- FURRYe38Mar 13, 2019Guru - Experienced User
Does 192.168.1.1 resolve if your connected thru the satellite?
