dopey1620
Jan 26, 2019Star
Orbi in AP mode with wired backhaul showing weird behavior
I recently set up an Orbi RBK53 system in AP mode (I don't need the orbi's router capabilities, as I'm using pfsense). The main orbi router is connected into a gigabit switch and one of the satellit...
dopey1620
Feb 17, 2019Star
I wasn't aware of problems with green and managed switches but now that I do some more digging with specific search terms yeah it seems like lots of people have been having the same problem.
I just switched to a zyxel gs1900-24 managed switch and am tinkering with the igmp snoopings settings but it hasn't made any difference.
Still good to know. Having the satellite wired directly into the router ethernet port is doable for now. I've followed up on my support case to see if they can tell us what protocol(s?) are used for the router/switch discovery and syncing.
dopey1620
Feb 17, 2019Star
Oh and one other good news. Now that the satellite is actually connected to the router directly and everything apperas to be working fine, daisychaining is doing what I want. Satellite-2 is connected to the wired satellite-1 instead of directly to the router. Signal strength to satellite-1 is much better and everything works great.
- ekhalilFeb 17, 2019Master
Great that things look good now.
One thing to be aware of is that wired backhaul together with Daisy Chain is not a good combination in the current software because of a software bug! Avoid having wired devices to the satellites for now until this is solved.
There is a beta software that is now being tested and it seems that this issue is addressed there :)
- dopey1620Feb 17, 2019Star
I've seen alot of comments to that but I've had a hard time finding specific details of the problem. Do you have a link to a post or something that describes what the problems are? So far so good for me :fingerscrossed: but it'd be good to know what problems I might run into.
