dopey1620
Jan 26, 2019Star
Orbi in AP mode with wired backhaul showing weird behavior
I recently set up an Orbi RBK53 system in AP mode (I don't need the orbi's router capabilities, as I'm using pfsense). The main orbi router is connected into a gigabit switch and one of the satellit...
Mar 20, 2019Guru - Experienced User
Yes thats a manged switch:
https://www.zyxel.com/us/en/support/DownloadLandingSR.shtml?c=us&l=en&kbid=M-01606&md=GS1900-24
Can you see if it has IGMP protocols enabled, if so, might try disabling this to see if he helps any. Been others mentionging that disabling IGMP on there switches helps with there orbi systems.
Might contact the Mfr to see if there any kind of configuration setting that would make the switch not direct packets for the orbi to see if this helps any.
