JBMN
Sep 24, 2016Star
Orbi Install Experience
Well, 2 hours later I'm up and running (mostly due to the first challenge). It was a bit harder than it should be, but workable for someone who has probably done many wifi acess points, modems, etc,...
JBMN
Sep 27, 2016Star
Hey DF, perhaps we are talking past each other, but I don't further unpack the actual firmware (.img) file. Netgear provide the firmware image and release notes in a zip file for the ORBI, so I do extract those two files. When I manually updated my satellite, it was looking for the .img file.
TomMac
Oct 14, 2016Guru
Well , a little late to the game , but no problem with my Orbi install.
5 mins from plug in of Router ( and a reboot of the modem ) it was hooked in. Satellite placed about 40ft away in closet came up in 2 mins.
Opted to direct connect to Orbi and just went to the base IP address to setup and change SSID/passphase. BTW, asked right away if I want to update the SW and with a click a few mins later done.
Satellite keeping everything happy at the far end of the home and no jumping problem between units I can see.... time will tell.
Signal strength is aprox 10 Dbi up over old router, so it's a good improvement.
Have to say it was pretty easy overall right out of box.
Down side is;
No guest mode ( tho I hear it will prob be sooner of later )
No external antenna port ( I have a 15dbi gain omni antenna in my attic i could hook to )
- peteytestingOct 14, 2016Hero
a single antenna would be useless in mimo and for wireless ac anyway , the days of external antennas is over beam forming also need 3 antennas
- TomMacOct 14, 2016Guru
Yes, did I say my old router was old... Brain fart on my part
