JBMN
Sep 24, 2016Star
Orbi Install Experience
Well, 2 hours later I'm up and running (mostly due to the first challenge). It was a bit harder than it should be, but workable for someone who has probably done many wifi acess points, modems, etc,...
TomMac
Oct 14, 2016Guru
Well , a little late to the game , but no problem with my Orbi install.
5 mins from plug in of Router ( and a reboot of the modem ) it was hooked in. Satellite placed about 40ft away in closet came up in 2 mins.
Opted to direct connect to Orbi and just went to the base IP address to setup and change SSID/passphase. BTW, asked right away if I want to update the SW and with a click a few mins later done.
Satellite keeping everything happy at the far end of the home and no jumping problem between units I can see.... time will tell.
Signal strength is aprox 10 Dbi up over old router, so it's a good improvement.
Have to say it was pretty easy overall right out of box.
Down side is;
No guest mode ( tho I hear it will prob be sooner of later )
No external antenna port ( I have a 15dbi gain omni antenna in my attic i could hook to )
peteytesting
Oct 14, 2016Hero
a single antenna would be useless in mimo and for wireless ac anyway , the days of external antennas is over beam forming also need 3 antennas
- TomMacOct 14, 2016Guru
Yes, did I say my old router was old... Brain fart on my part
