twrerctr
Jun 03, 2017Initiate
Orbi installation - firmware update - dead router
Followed quik start guide, everything connected, connected the app, changed the SSID and password, then was give option to update the firm ware. Said it would take about 3 minutes, then after a few ...
st_shaw
Jun 03, 2017Master
When you did the reset did you press and hold the reset button for a very long time, until the green light started flashing? That should reset everything. If that doesn't work there's probably some way to use tftp to reload the firmware. I've done this on other bricked Netgear routers but not on Orbi yet.
